tzimber 3
not sure what happened, but my system doesn't seem to respond to alarms.
when device is breached, i do see the alarm on my app, but the scene that should run when alarm is running isn't triggering.
Also, i i try to use the fast actors on the alarm panel, it's not doing anything.
for example, i choose several lights to turn on when alarm is triggered, but the alarm state starts and nothing happens.
if i manually run the scene that turn the lights, or the scene that arm some sensors its working fine.
this was working perfectly for several years, i have no idea why it stopped.
HCL lite
FW:4.600
no errors on the system.
scene marked to run when alarm is running.
* i have cleared consumption history - no change
* i have rebooted the system - no change
Any ideas anyone ?
thanks !
When doing some further testing i have some more information.
the scene that I'm doing suppose to turn in lights when alarm is triggered ( this option from the alarm panel isn't working)
i crated a scene saying that:
Device Group = = Breached and armed >
than > Device Group = = TURN ON.
now,
what I have noticed is that if on the first device group, I'm adding only one sensor, for example 1 motion sensor its working fine.
but if I add 2 or more sensors, it doesn't work.
dose this means that when i chose multiple devices and say " Device Group Breached And Armed " the system is waiting for all devices on this group to be breached and armed to trigger the scene ?
this was defiantly wasn't the case in the past.
dose this mean that now i have to each sensor separately in order to turn on some lights when alarm is triggered ?
Edited by tzimber0 answers to this question
