ChristianSogaard 74
I have a Matrix from Logic Group that need to communicate with Fibaro Wallplug with Association.
If a uses the Matrix - this can turn on and off the Fibaro Wallplug
If I uses the B button on the Fibaro Wallplug - i cant communicate back to the Logic Group / Matrix - because the Fibaro Wallplug is missing Basic Report
The same for a scene that stops the Fibaro Wallplug - this is not feed back to the Matrix
So its the scene way - or do someone have a fix. @A.Socha do you know if Basic Report is going to be supported in Fibaro Wallplug ?
I was told I could do this with a parameter that sets the status, without ak activating the function behind the pressure (because then you have a loop).
not sure how
