Prohibit the execution of a scene
Hello everybody !
I am faced with a small problem to build one of my scenes. Yet I thought I had correctly reflected the trick! ah ah
Basically I have motion sensors all over the living room that turn on my lights; So far so good.
The scene is as follows:
/monthly_2020_12/living1.png.d4b8c1a2de3ae7225f15e29ab79e7a19.png" />
Then I made a "cinema" button that when I activate it stores a value in a global variable. This allows you to disable motion detection and keep the light dimmed in the room.
In a normal case, without the cinema button activated, the lights go out after 10 minutes of no activities.
But I was thinking of protecting the scene that turns off the lights with the cinema mode global variable.
I think I'm missing out on something ....
Looking forward to a charitable soul! : D
thank you in advance
PS: I don't know LUA and I exclusively use the graphics builder
4 answers to this question
    Me again ! : D
    So I modified the execution of the "Lights LifeSpace Off" scene via a custom event. It seems to work, I don't have hot tubs in the dark!
    Hoping to have helped someone in the process. See you soon.
    An other way could have been to create a new profile "Cinema" where some scenes would be disabled and others not...
    Glad to find someone who doesn't use LUA !
    @wienog I will actually try your solution because even with a custom event it does not work as I want ...
    Yes, I use this method and it works.
    when night mode is active and the morning routine sets the profile back to Home I don’t want te arriving home routines to start. So I disable and enable these.
