Satel Intgra outputs problem
Edited by ruudalblas
6 answers to this question
For me the outputs / zones etc are all hidden and therefore unusable. You may need to reload the plugin, I haven't tried yet
Do agree with @Krikroff, you should try to reload your configuration from the plugin. I did it many many times :) and it works very well, at least never add any issue.
And after reconfiguration of your satel plug-in: wait... wait and wait :) It might take up to 10 minutes before all zones and outputs are visible, have the right name and are usable in your hc3.
Excellent remark @Comfortica! you're right we need to be patient :) it can take some time and it's always better to let the process ending without playing too much with the HCzztill it has finished the job.
    The outputs are visible and seem to toggle, the icons changing. But when you want to create a script the output doesn't seem to change state. as workaround I let the outputs in Satel  switch a zone and then pick up the status in the script
