Joost Thijssen 0
I recently got my HC3 and I've been experimenting with some of the QuickApps including the Philips Hue quick app to control my Hue Lights.
)While it works pretty well I found it was way harder to get the colors right using the Fibaro Color Control than it is in the official Philips Hue App, also in the Philips Hue app you can create a scene that will control all lights in a room or group. When using such a Hue scene all lights change at once, with the quick app and a HC Scene the lights get controlled one after another.
I couldn't find any way to set a Philips Hue scene using the existing Quick App so I wrote the included QuickApp to do so, please enjoy, extend or change, or maybe the functionality can be included in the existing QuickApp.
How to use:
1. Make sure you have the Philips Hue Quick App (HueMain) mentioned above up and running.
2. Create a scene in the official Philips Hue App and give it a unique name.
3. Install this Quick App (HueSceneRunner)
4. Check HueMain's variables and copy the values for 'HueBridgeIp1' and 'HueUser1', place them in HueSceneRunner's variables as HueUser and HueAddress.
5. Check HueSceneRunner's device number and remember it for now.
6. Create a new Lua Scene in HC for each hue Scene you want to use. Set Run Scene to manual. If you want you can use attached icon. It is recommended to call it something like "Hue 'xxx'" where xxx is the name of your Hue Scene.
7. Add this code for the 'action' part:
8. Replace XXX with the deviceId you got at step 5, replace YYY with the exact name you gave the scene in the Philips Hue App and save the HC Scene.
9. You're ready, now you can just trigger the created HC scene manually or run it from another HC Scene using the 'Run Scene' Block.
Troubleshooting:
If you access the HueSceneRunner's GUI you can 'browse' detected scenes, also you can instruct the QuickApp to check for newly added Hue Scenes.
Joost
Edited by Joost ThijssenCorrected interpunction
4 answers to this question
