Robefa 0
Hi. I have a double switch 2 and I want to configure it so it is impossible to activate both outputs simultaneously. I want it to control a double speed fan with two L inputs (double windings) so when one output is closed and the fan is running at one of the speeds the other output can not be turned ON and vice versa. The fan is connected to a mechanical switch that alternates the L inputs/speeds. I want to automate the Fibaro switch so when I have mechanicly switched the fan ON to low speed and the humidity goes above a set treshold in Athom Homey the Fibaro switch sets it to high speed (Q2 is ON and at the same time shuts off Q1). I know this can be done in a Homey Flow -then: turn off and turn on but I want it to be fail safe, a function inside the Fibaro switch
is this possible with this switch?
