Struggling with connection of Fibaro Double Switch with double wall switch in 2-way mode ("stair switch" mode)
so I understand that if I have double wall switch (like
for example), each button controls different light. I can connect Fibaro Double Switch 2 modul inside this wall switch and I wll be able to control these two lights also from my HC.
In my case I have two double wall switches on both sides of living room. They are both connected to the same two lights and I can control these light from both of these double wall switches.
I was trying to Google this case but I didn't found any scheme how to connect Fibaro Double Switch 2 module to this, so I can still use my wall switches and also be able to control these two lights via my HC.
Thank you very much for your help!
Edited by skorpa
you can tray this.
