Poom 7
I uses two HC3 with the latest firmware 5.061.36 which allows gateway connection feature. I connect both HC3 one as Master and one as Slave and has been using this setup for over 2 weeks fine with no problem. My setup is on Master SIDE B mode.
Two days ago, HC3 restart and booted into Side A mode (with older firmware) with no reason. I booted into recovery mode and switched back into SIDE B mode to firmware 5.061.36 version. After I booted back into my SIDE B setup, the gateway connection to my slave HC3 disappear as if I never connect slave gateway before. Normally when my slave HC3 offline, it will show as slave gateway offline and can reconnect automatically when Slave HC3 back online.
My slave HC3 is now in the gateway available list as if it has never been add before. I try to click the connect button but it said "Error 409 - Conflict".
Please help me reconnect my slave gateway.
