Pete123 3
I have an issue with some declarations on Home Center 3.
what I want to do is:
if:
-all lights are off
-lux below limit
-cleaning is "no"
-motion from any motion sensor
-light control is set to "auto"
or if:
-any lights are on
-lux sensor change value
-cleaning is "no"
Then I want the scene to run.
With the current declarations I have, it always trigger if any motion is detected.
If I only use the first or second part of mentioned above, it works as I intend it to.
I have tried to remove parts of each criteria mentioned above, but it does not help, only if I limit it to one or the other part.
I would really appreciate if someone could help me point out my mistake:
update of lua
