Anya 0
Hi everyone!
I have Fibaro Home Center 2, Fakro ARZ Z-wave roller shutters (3 of them) and Fakro ZRH12 Z-wave remote control.
I want to be able to controll all 3 roller shutters with Fibaro Home Center 2.
As far as I have understood firstly I need to add all 3 roller shutters to Fakro ZRH12 remote control, so they can be controlled by the remote.
I am confused what to do next:
- I tried adding Remote control ZRH12 to Home Center 2 using the following procedure: setting Home Center 2 into "Add new device" mode and setting the remote control to "Ln" mode (Adding as secondary controller). The remote successfuly added to Home Center 2 but I can only see it shown as the device with the "remote control" sign and it has no functionality (no buttons, no on/off, no up and down signs, nothing). If I try to use the phisical remote to control the shutters (as I did at the beginning) I cannot access them through it as well.
It seems that all the roller shutters are deleted from the remote after adding the remote to Home Center 2.
I also tried to add roller shutters to groups before adding remote to the Home Center 2 but still I can't access the roller shutters through Home Center 2 after adding the remote to it.
Can somebody help me, what is the proper procedure of adding the roller shutters to Fibaro Home Center 2, and do I need that ZRH12 remote controll at all? Maybe it is possible to add the roller shutters directly to home center 2, without using remote control?
Any suggestions?
Thank you in advance!
7 answers to this question
