GruffT 0
HC2 running 4.600. Pretty simple setup with just Fibaro Dimmers and a couple of blind controllers. 2 remotes which trigger LUA scripts. Nothing complex.
The unit is running really hot and if I look in diagnostics, 1 CPU is maxed out then it flips to the other and back. I also lose z-wave connectivity once every couple of hours and have to reboot. A couple of times the unit wouldn't come back up at all and I had to use recovery mode.
Is this unit just faulty? Would a downgrade to 4.590 help? (and does anyone have the link to the patch file - the usual format doesn't seem to work).
If i can't get this resolved, I'll have to go over to a vera!
GT
