petrkl12 206
QA for creating HomeTable in global variables in HC3.
Why using hometable?
Instalation:
1. upload this QA
2. In QA variables you can change name for hometable, name for scenes and time for regular update of hometable
/monthly_2021_02/QAHomeTableVariables.png.709f05f8df61f550dfe36b18716dd329.png" />3. In QA -> source files -> ManualData you can add your own data (it will be also saved in final hometable in global variables)
How to read data from hometable:
Names for rooms, devices and scenes are corrected by following replaces:
{["Á"]="A",["Ä"]="A",["Ą"]="A",["À"]="A",["Â"]="A",["Č"]="C",["Ć"]="C",["Ç"]="C",["Ď"]="D",["É"]="E",["Ě"]="E",["Ë"]="E",["Ę"]="E",["È"]="E",["Ê"]="E",["Í"]="I",["Ï"]="I",["Î"]="I",["Ĺ"]="L",["Ľ"]="L",["Ł"]="L",["Ň"]="N",["Ń"]="N",["Ó"]="O",["Ô"]="O",["Ö"]="O",["Ő"]="O",["Œ"]="O",["Ŕ"]="R",["Ř"]="R",
["Š"]="S",["Ś"]="S",["Ť"]="T",["Ú"]="U",["Ů"]="U",["Ü"]="U",["Ű"]="U",["Ù"]="U",["Û"]="U",["Ý"]="Y",["Ÿ"]="Y",["Ž"]="Z",["Ż"]="Z",["Ź"]="Z",["á"]="a",["ä"]="a",["ą"]="a",["à"]="a",["â"]="a",["č"]="c",["ć"]="c",["ç"]="c",["ď"]="d",["é"]="e",["ě"]="e",["ë"]="e",["ę"]="e",["è"]="e",["ê"]="e",["í"]="i",["ï"]="i",["î"]="i",["ĺ"]="l",["ľ"]="l",["ł"]="l",["ň"]="n",["ń"]="n",["ó"]="o",["ö"]="o",["ô"]="o",["ő"]="o",["œ"]="o",["ř"]="r",["ŕ"]="r",["š"]="s",["ś"]="s",["ť"]="t",["ú"]="u",["ů"]="u",["ü"]="u",["ű"]="u",["ù"]="u",["û"]="u",["ý"]="y",["ÿ"]="y",["ž"]="z",["ż"]="z",["ź"]="z"}
Hometable in global variables will be overwrite only if newly generated hometable will be different.
Version of QA HomeTable: 0.12 - 21.1.2021
11 answers to this question
