Hi everyone!
I’m quite new to the Fibaro world. In fact I’m just fiddling around with my newly bought set of equipment in my “test lab”. I can get everything to work as expected and wanted except for one thing:
Associations on the fgs223 don’t seem to work at all. I tried everything:
- including both a wall plug and a fgs223  non-secure
- including both a wall plug and a fgs223  secure
- resetting everything (including HC3) to factory defaults
- setting all relevant parameters to all possible values
- looking into the jsons the api provides
What I can achieve is:
- Associate a button of my KeyFob to a WallPlug - works charming even when the HC3 is not present.
- set the association in a fgs223 for either endpoint 0 or endpoint 1 to the correct id of a WallPlug (json confirms that the association is set accordingly)
Whatever I do the associations won’t trigger neither a WallPlug nor another fgs223.
Is there any known issue according to associations with the fgs223?
Maybe some trick to get it working?
I could (and most likely will) help me out with scenes, but that’s not want I want...
What am I missing?
Any help or pointing into the right direction is very much appreciated!
Best regards to all of you,
Ben
    *push*
    ... still no luck on my side.
    Anyone?
    Best regards,
    Ben
    Hello. I have many (>20) associations between various key fobs, double switches, door/window sensors and roller shutters.  Associations to turn on and off work well, for example "on" when a door opens, "off" a few seconds after it closes.  Associations to toggle are not supported by Fibaro, for those you have to use scenes.
