Dacron 2
Hi
I'm trying to set up a "Good Night" command through Alexa. My problem is Sky box's use a IR toggle code to turn them on and off so if the sky box is off it's turned on by the IR sent in the scene. I have set up a smart implant that monitors the HDMI signal and indicate wether the box is on or off. I just need to figure out the code needed in a scene or virtual device to stop the sky IR code being sent if the units already off. I know this is possible with Lua but not sure of the best method or code with HC3.
