Gateway startup
hTiger1
Gateway startup
Trigger on every startup, which is shown in the manual.
I can not make it work, has anyone tried it?
4 answers to this question
  • 12 hours ago, hTiger1 said:
    Yes it is the trigger from the manual, that I can not get to work, the scene does not start when restarting the gateway?
    The problem is solved.
    The trigger works in my case when I put this timer on.
    fibaro.setTimeout (25000, function ()
         fibaro.call (163, "setConfiguration", 12, 1, 56)
         fibaro.call (163, "setConfiguration", 13, 1, 2)
    than)
    normally se-start
  • 54 minutes ago, tinman said:
    normally se-start
    than)
    the trigger is working even without, in your case the se-start started while z-wave engine was still busy, so setconfiguration was not send. Generally good idea to give HC3x some time to start up properly before the startup trigger is doig any action.
