POWERVIEW QA from Fibaro - stops working after ...1 day
Hi
when I add the powerview QA from fibaro HC3 (the built in one) it grabs my scenes from powerview and all is good. I can activate the scenes in "preview" and via lua.
But.. the next day.. they don't work anymore.. I can then remove the QA and readd it.. then everything works again.
Does anyone outthere use the powerview QA? have same experience? found a solution?
Right now my only idea is that because I had automations running natively in powerview they ..for some reason.. break the link.. so after an automation has run in powerview.. something happens.
I've now turned off my automations in powerview app and created a simple lua script to close the curtains tonight 30 minutes after sunset.
tomorrow we'll see if they still work.
8 answers to this question
    Unfortunately.. today they didn't work again.
    A reboot of the HC3 helped.. but of course.. that's not a viable solution.
    Does anyone have any thoughts on the issue?
    Same here. Fibaro is aware of this issue though, hope this gets fixed asap.
    Which FW is your HC3 running?
    newest  beta:
    5.062.40 (beta)
    pssvr - Glad to hear that they are aware of the issue.. Here's hoping they will get a fix out soon.
    that's actually interesting, because the plugin itself has been not changed since years. Out of curiosity, did it worked for you guys with previous HC3 firmware without issues?
    I can't answer that as I've only recently started using it.
    but it consequently stops working after a day.. something seems to happen overnight.
    a reboot of HC3 fixes it...for the day.
    obviously it's not an option to reboot.
    How can it not have been changed for years when HC3 is.."new" ?
    the plugin has been developed some time ago, and was working on HC2, so because it was working, HC3 got it as well (some other plugins, because they stopped to work, got removed/never implemented on HC3).
    So you say, it works, but stops overnight (i assume then if you run play scene nothing happens? or no communication?). Just trying to understand what going on.
    ok. thx for the clarification.
    so yes... if I add the plugin .. enter the Powerview hub IP .. then it works..
    I then go to sleep..
    and next day the plugin stopped working.
    I can reboot the HC3.. then it works again..
    then rinse & repeat  :)
    I got a reply from fibaro support.
    they're aware of the issue and are investigating already.
    time to fix.. unknown.
    so if I want to use hc3 for powerview.. I guess I'll have to use the api to send requests over http.
