HC3shows starting services after restoring cloud backup...
I am recently migrating from HC2 to HC3. Yesterday i implemented a lot of devices and scenes i was close to a final situation. It was running all normal and everything worked fine. Until i thought it would be smart to create a backup and after this problems started. After backup the system reboots and showed a long time starting services. After a whie it automatically restored to a previouss version, but without a lot of devices and scenes. IS there a way to check my backup or repair something or what is wrong? Any suggestions?
4 answers to this question
you have two systems A and B
Try start recover and repair the opposit one.
Succes
//Sjakie
    Goedemorgen Sjakie,
    Thanks for your assistance!
    As far as I know it automatically recovered to the other system. After this i went to recovery mode and try to repoair the opposite. But it didn't seem to work, I ended in the same situation as described above.
    So i think i need to build up again from last working backup? ?
    Greets, Remon
    Succes
    //Sjakie
    Hey @Sjakie,
    Found out it will be this problem ?
    Again thanks for your help!
    Greets, Remon
    Edited by impact
    @SjakieEverything up and running, failure didn't come back anymore. Now slowly building my automations again ?
