JcBorgs 52
Relatively new to this and can’t get it to work, have searched in other places/forums but can’t find any good information so hoping for some guidance here.
I have a HC3 and two RaspBerry Pi 4, one running 32bit OS and the other 64bit OS.
Have now tried on both of them to first setup InfluxDB (version 1.8.4 on the 32bit and version 2.0.4 on the 64bit), so far so good and that piece seems to be working. Then I want to get the HC3 to send data into InfulxDB and saw that Telegraf has a Fibaro plug-in. Had some hassle to configure it, mostly on the 64bit Raspberry. But eventually got it installed on both, but here my problem start.
Both InfluxDB and Telegraf reports as active and running in both of the Raspberry’s. But as soon as I add configuration for the Fibaro plug-in in Telegraf I start to see messages when checking the Telegraf Status that there is an Error, something related to JSON not being able to pharse a “value.dead” as string (will copy the exact error message in a later post).
But my first questions are:
1. Is the Fibaro Plug-in in Telegraf compatible with the HC3 or is it intended to be used with the HC2?
2. Are there any alternative methods of getting the HC3 to log data to the InfluxDB?
3. Anyone with a similar working setup that can share some config examples? (Setup = HC3 logging to InfluxDB with Telegraf)
13 answers to this question
