Guest Dexter
Hi all,
I'm using HC3. So, i've now installed two heat controllers as a kind proof of concept - I don't use the the heat controllers with external temp sensors.
What I have is a Hue motion sensor with a temperature probe outside those both rooms. Hue motions sensor is installed in the floor adjacent to those both rooms.
Let's call it Floor 1 - I can select hue motion sensor as the main temperature sensor for Floor 1 - But it isn't possible to select this sensor as the main sensor for the both rooms with the heat controller?
Floor 1 and both rooms are in the same section.
As far as I understand I can only select a temperature sensor that is assigned to that very room? What is then the purpose of sections and zones?
