HC3 Interactive push Yes/Nos sending action failed
Hi guys,
I´ve set up a scene, where I want my HC3 to check if any lights are on after I leave my home, if so, it sends me an interactive push notification to my iPhone with question, If I want to turn everything off with Yes / No, if Yes is pressed it should run scene that turns everything off.
Almost everything is running ok, the "check if lights are on" scene is sending the interactive push notification and also the scene for "turn everything off" works fine. But there is a problem with the push notification Yes / No sending. If I press Yes, it brings me another notification with error message shown in the picture. Any idea what might be the problem? Btw, I´m only simulating the actions by running the scene from HC3 panel, as for it running as intended, I need to be away from my home.
Thanks a lot!
Edited by Saaw
misspell
I have a similar issue, tested on HC3(build 5.061.36 beta) and HC3L(build 5.070.42):
/monthly_2021_03/photo_2021-03-27_12-20-59.jpg.fa29a1feb7fe751b70643e557a074e97.jpg" />
I have interactive notifications programed and whenever I press 'yes' it should execute a different scene but I get this error.
Also tested by making a simple block scene and I still get the same error.
    Yes, build 5.070.42 also with me.
    Update: Fixed it by loging in and out of the 'Fibaro Home Center' mobile app
    It seems that for some reason the app wasn't working properly
