HC3 Stuck at starting services
HC3 stuck at starting services
4 first lights steady yellow
5th ligth (cogwheel) steady red
Any suggestions?
The fact that the fifth LED is red only means that you have not configured any Installer access.
If you want to turn off the LED, you can do as I do, enter [email protected] as the authorized installer.
But if the box does not want to start, try restarting it.
Edited by RH_Dreambox
