Hello fellow Aussie @kelvincoffey
Have a look at this post, it details my journey to fix light flickering ... hopefully it will help you too
An interesting footnote, to echo Alex's point about trying different bulbs: I ordered a 5th LED bulb to add to 4 I already had, to use in a multi-bulb fitting.  The 4 had already worked flicker free in another fitting.  Even though the new bulb was exactly the same, it has some sudden light bursts when dimmed (the others do not). I contacted the retailler who told me that the new bulb has "an improved updated driver".  So it seems that fickle incompatabilities between driver and dimmer can occur even within the same make and model.
    On 4/8/2021 at 7:46 PM, kelvincoffey said:
    I’ll believe it when I see it
    ive got 20 dimmer 2s that are near unusable and I’ve stopped deploying zwave as a result and using good old Clipsal normal mechanic switch.
    and when people ask why half my house is automated and half isn’t, I just say because fibaro is absolute trash.
    change my mind fibaro.
    @A. Przybecki   again...  false promises...  just another day at Fibaro hey?  9 days, no contact.  Shame on Fibaro.
    As this update (4.61) makes it not longer possible to change temperature setpoint on Heatit ztrm2 and Ztrm3 thermostats from android app (v.1.27),
    this update v.4.61 should be changed to a beta version to avoid unintentional updating..
    Edited by RobertL
    Should I make over 35 soft reconfigurations for my danfoss valves?
    WHY is this needed? Has that been clarified?
    Is it a repair action for an errative update? I used my backup and  will wait for a more mature update.
    • 1 month later...
    I apologize for the late response @kelvincoffey
    I would like to change your mind.
    Please send me:
    1) Installation diagram how do you connect dimmer2?
    2) Do you use bypass?
    3) What kind of bulbs do you use (LED, ordinary)?
    4) How much power do I use the bulb (3W, 50W)?
    5) Is the bulb adapted to work with a dimmer?
    • 1 month later...
    Same problem to me..
    Edited by guptashivamm1
