HC3 and SATEL integration
kwroblewski
Hi
I have a problem with integration HC3 with SATEL Integra after migration from HC2. Integration with HC2 worked perfectly but now with HC3 only partially.
Motion detector and all inputs from Satel i see in history and working in scenes, but change state outputs HC3 can not see in scenes and history.
Does anyone have solution for this problem?
My version 5.070.42
Hi ,
For me the same problem with version 5.070.42 , all inputs are working exept the output's. When i change the output's in Satel i see the sensor in Fibaro changing but i can't change the state from fibaro HC3 in satel.
This is not funny after converting my system from hc2
I used it a lot and HC2 worked fine.
Leon
Hello guys,
Have you solved your problems? It looks I have similar ones. All Satel Zones/Outputs are in HC3 but they aren't updated/changes at all.
No solution for 2 years… Why didn’t I turn to this topic earlier? Before migration to hc3…
