zigbee and rf hubs on HC3?
can i connect a Zigbee or RF hub to HC3 over IP?
You can get zigbee devices connected to home assistant running on a mqtt server. Then using the quick app rangee made zigbee2mqtt (on Marketplace) you can integrate your zigbee devices to HC3. All you need are a hassio running pi and a sonnof CC2531 flushed usb (zigbee controller).
Steve,
The simple answer is: No. Fibaro HC3 is now more than a year old and still RF and Zigbee and other announced features are not yet working (unless you use complex workaround  with extra hard- and software).
There is absolutely no knowledge about if or when other protocols that were promised in the slick marketing will be available, if ever.
I see you are a newbie: best solution might be, if still available to you, to bring your HC3 back to the seller and ask for your money.
