Since 1.12 the location is no longer correct. Neither in the HC2 nor in the HC3.
Everything is OK in the browser.
In the old Fibaro for iPhone I see all my 6 Cameras, 4 of them ar Mobotix, 1 Axis, 1 Dlink. See screenshots and compare.
In the new Yubii app i see only the cheap Dlink.
So for me this app is more or less useless.
How can you tell that the location in not correct? We would like to reproduce the issue. Note that location in the app is taken from your GPS feature, make sure that it is turned on.
I forwarded that to the iOS team :)
    Dear @T.Konopka, thank you for the feedback.
    As for GPS, it is turned on on all devices, iPhone, iPad and Android tablet. They all show me the same wrong place.
    See map.
    Edited by jwi
    wrong map deleted
    Thanks for that!
    See map.
    GPS in mobile can detect your locating by two different methods.
    1) via satellite (hardcode :)  for mobile batt)
    2) via Mobile data (cellular repeaters)
    so, i f your mobile use only cellular data and nearby repeater 18 min from you - here is all ok ? as for me.
    Edited by hater
    and please don't forget, when you use GPS via satellite, you might get wrong data as well, if the emperor is flying drones to spread out democracy in galaxy
    As so often, I cannot follow your explanations. And whatever you want to tell me,
    I think it's a bug in the app. Because: all devices correctly display my street and
    house number. But this street does not exist in the indicated place.
    For me it never worked properly
    Two scenes one for goig away and one comming home.
    If push action it is notice me I am home or away.
    If I go away or comming home >>>>nothing
    remark my mobile mast is on 150 m
    In settings I have 150 m too
    //Sjakie
    Is there a chance that DLink uses JPG stream and other use only MJPG?
    Is it your location, meaning your phone's location? Or is it your gateway's location?
    Note that the app does not report your current location as you travel.
    So geo-fencing cannot work at all? ?‍♂️
    @Rover , geofencing works - meaning that the app reports the location to the gateway. But you will not see the location of your phone in the app (your current location or location of a user) - this is not a feature.
    The DLink Camera works with JPEG and MJPEG. I then examined it more closely and
    found that the problem is special characters in the password, e.g. "/ ()" etc.
    In the browser preview there was no problem, but there you could see that in the url
    instead of "/", a "%2F" was used. After creating a user with simple passwords in the
    camera, I see the cameras in the app. So this point would be solved somehow.
    I never just use simple passwords.
    Regarding the location, all devices, iPhones, iPads, Androids are in the same house as
    the gateway. As already mentioned in the gateway everything is correct, only in the
    devices is the wrong place but the correct street and number. However, this street does
    not exist in the location shown.
    So, this is some sort of workaround, but still the password should not affect the preview. I'll pass that onto the QA Team.
    Where exactly in the app can you see that? Because, if you say that the device reports the wrong location then it has nothing to do with the app itself as it simply takes the location from the GPS feature on tha device.
    I want to check how can you see that the Yubii App on the device reported the wrong location :)
    +1
    lol.
    maybe he walking with HC3 in hand?
    Edited by hater
    In ... More -> Settings, see screenshot
    I made the correct street address invisible, not everyone has to know where my office is.
    You're wrong again, I tied the HC3 to a drone that follows me.
    Maybe I haven't made myself clear enough. But I wrote that there are no problems in the browser preview.
    But with this url like in the screenshot I don't see any cameras in the app. If I remove the "/"  (transleted to %2F) from the password, everything is OK in the app.
    Edited by jwi
