Hue White and Colour Ambiance GU10
pali26
Afternoon,
I have purchased the Hue White and Colour Ambiance GU10 lights and the bridge and wanted to know what fibaro product I would need to buy?
what I need the RGBW module?
If you have the lights and the bridge, you have a working setup. Install the bridge, install the lights and control them with the Hue app.
You could integrate them in a Fibaro Homecenter, but it is not necessary.
I’d say the RGBW module in such a situation would even worsen it. I personally keep my lamps power input permanently on (“hard-wired”) and control tle Hue bulb either via Philips application, either via Yumi application (using Fibaro plugin installed in HC). Using plugin enables you additionally to design scenes within Fibaro environment.
Note that the Hue device state you should read from the “on” variable and not from the “state” variable as it is in case of ordinary lights.
