Spontaneous movement of blinds
Hello everyone,
I also found a problem with the control of blinds.
I have 3 blinds controlled by 3 Walli Roller Shutter FGWREU-111 v5.1. on HC3. Two of them are in the "Roller blind (with positioning)" mode, ie Parameter 151 (Operating mode) = 1. For the third, I also need to control the position of the slats, so they are in the "Venetian blind (with positioning)" mode, ie parameter 151 (Operating mode) = 2.
When I give the command to pull all blinds through the LUA scene, the blinds move up (level = 100), but only blinds in the Venetian blind mode after about 1 second spontaneously (there is no command in the LUA code) they go down to level 95. Why?
I thought it was related to parameter 153 (Set slacks back to previous position), so to be sure in the LUA code, before calling "open", I'll set the slats level to 0 (perpendicular to the window). But even this doesn't help. Any tips on how to fix the problem? Thanks a lot in advance.
M.
I have the problem that a random roller shutter 2 opens spontaneously a blind or my gate.
For example, no one has been home for 7 days, so no unexpected commands etc.
I use 12 roller shutters 2 on HC2
Has anyone an idea how I can solve this problem please?
I've been using roller shades for more than 2 years. But after one year, the pull at the bottom of my shade extends the entire length of the shade and it has come loose on one end. I tried unscrewing the cap at the end but it came loose and tried to re-roll the shaded part into the roller and close it but it did not stay. It seems there was some kind of adhesive used to keep it in place. I tried a lot to fix it myself but I failed. After all my hardwork I realized it could be fixed only by a professional, so I called the technicians to fix
and they did it. So it's better to contact a technician to fix your problems.
