Need LUA scene that changes device attributes based on a trigger
So I'm relatively new to Fibaro and little programming experience, especially in LUA.  I'd like to have the following happen:
If overhead door is open (DSC virtual device from Per-Olov Sjoholm) I'd like Device ID 5 parameter 14 changed to 1
If overhead door is closed (as per above virtual device) I'd like Device 5 parameter 14 changed to 0 (which is also default)
Any brilliant advice for a newby?  Ideally I wish Fibaro supported the Z-wave device I'm using but despite sending the configuration files, it seems very uncertain on if and when they might support it.
All I know is the first part of the LUA script might be as follows:
if (
 ( tonumber(fibaro:getGlobalValue("Z8GarageOH")) == tonumber("1") )
or
then
