petrkl12 228
QA for Honeywell Evohome
60 days trial period - than you need license key: 30EUR via Paypal account
For license key I need your HC3 (or HC3L or Yubii) serial number: HC3-xxxxxxxx
Ideally include your device serial number and QA name in the payment note.
QA:
Icons:
How to install:
1. upload QA to HC3
2. set variables LoginName and LoginPassword
3. you should see list of Evohome devices
4. you can create child QAs only for selected evohome devices or create QAs for all devices via press one button
Other parametres:
Icon - id of icon for main QA (ie. 1401) you have to upload icon via other devices ie. multisensor and get icon number (save icon picture from browser and there is icon id)
PrefTempAPI = V1 or V2 - which api version should be used for temperature reading (V1 is older but more accurate, V2 is newer api and use values as you have visible in display, default is V1 (I preffer more accurate temperature, in details you can see both values)
ThermBtnSet = "TemporaryOverride" or "PermanentOverride" - which mode will be setup when you press button Set (as on picture bellow)
ThermBtnSetTime = 0 - this is for TemporaryOverride mode in case of press button Set, time in hours, 0 means till next change based on schedule, def. is 0
EvHUpdtInterval = 1 - refresh interval of values from evohome devices in minutes, def. 1 minute
EvHUpdtSchedule = 60 - refresh interval for schedule plan for thermostats from evohome in minutes, def. 60 minutes
EvHUpdtInstall = 240 - refresh interval for reading instalation things from evohomen ie. new devices , def. 240 minutes
For manual refresh you can press button Update. Also some parametres you can setup directly in QA for thermostats ot temperature.
There is also autoupdate mechanism. All your QA Evohome devices can be updated remotely.
QA is developed only for EMEA region. You should check if you are able to login to your Evohome here
/monthly_2021_05/EvH_Temp1.png.28df7e9e10cb7df8910968c389bbff09.png" /> Edited by petrkl12Top Posters For This Question
12
5
3
2
May 20
4
May 19
3
Jun 9
3
Jun 1
2
petrkl12 12 posts
WJM 5 posts
pnutp0wer 3 posts
ArjanC 2 posts
May 20 2021
May 19 2021
Jun 9 2021
Jun 1 2021
petrkl12
QA for Honeywell Evohome 60 days trial period - than you need license key: 30EUR via Paypal account Please login or register to see this code. For license key I need your HC3 (or HC3L or Yub
petrkl12
some news: - added calling APIs version1 where is more accurate temperature - added support for DHW (without any testing) - some design changes b63b6ad190df1ccf5db7187a4b1b
Jurgen van Beek
can I be added for testing the Evohome on the hc3
41 answers to this question
