[SOLVED]HC3 crashes after latest update
I updated my HC3 the other day and now it crashes.
I've tried running autorepair and starting from both A and B.
I get it up and running after an hour or so, but then it is online a few minutes and crashes again..
Anyone else with the same problem?
4 answers to this question
    Now it will only boot in recovery, cannot et past it.
    My house is down...
    Tried autorepair
    Tried repairing system
    Tried booting from system B (doesn't work... just ends back up at recovery as system A after an hour)
    Does anyone know if I loose everything by chooseing recover system? I can't find any backup as I understand it is stored locally on the HC3 (how do i access it?) and the backups stored on the cloud I cann't find anywhere
    Edit: Also I can't submit a ticket as it tells me my password is wrong and it will not reset..
    Help!?
    Edited by Kouzco
    got it up and running... for now
    Hi Kouzco! How did you fix your issue? I seem to have a similar problem. My HC3 have been running 5.070.42 for several weeks without problems, but this morning it was not responding in the app. I went into web interface and it showed the recovery console.
    Best regards,
    Erik
    Hi!
    Sorry for the late response, I don't have waning set up for replies :/
    I ended up clicking "recover system A" which rolled me back 6-8 months. Had to redo a bunch of stuff, but atleast got it back up and running.
    Have you got yours up again?
