tzimber 3
Hi Everyone,
so I'm having this issue that is driving me CRAZY !
I'm building a new home, and i just bought HC3 and lots of switches.
I built my system in a way that the switches will be installed in power boxes, instead of inside the switch box, as I found it very crowded to fit in.
So,
I was installing one of the units today, I have one light, connected to 3 switches ( so I can turn this light from any of this switches)
when connected without the Fibaro switch, I can turn the light On and Off, from any of the switches.
when I connect the fibaro module, the switches doesn't seem to have any effect. if I turn the light On and Off from the up it works fine, but the switches dose noting.
so to figure out what's going on, I took the switch, and just built the same setup on the table, and everything was working fine.
So, what can cause this issue?
if without the fibaro switch, all of the mechanical switches turn the light on and off, why dose the switch fails to receive the on/off signal ?
also, if i take another mechanical switch, and connect it directly to the module, inside that main power box it dose work ! even though that this mechanical switch is connected to the same mechanical switch that is like 4 meters away inside the wall.
but the one inside the wall has no effect, and the one next to it dose work !
i have added a diagram of how I connected everything.
Thanks !
33 answers to this question
