Bert 0
Hello everyone,
I'm considering to use a Fibaro FSG-213 in combination with a wired PIR sensor and Home Assistant. The PIR sensor would be wired as switch and the Home Assistant would be configured to control the light. See
for another description and a wire diagram. The special aspect is that the switch should not switch the light on when motion is detected but leave decision to Home Assistant.Is that a possibility? If so, how should I configure the switch?
Thanks in advance!
Bert
Edited by BertLink to comment
