fdsjkl 1
I've got a licensed electrician to install some 24v LED strips in 2 rooms with dimmer 2+ bypass 2.
When first installed, both had the same warning "Caution! Overcurrent detected." But a quick force auto-calibration solved the issue. I need to force a calibration every time power cuts out. They've been working fine for 2 months with no issue.
Today, for some reason, without making any changes to wiring or setting in Fibaro, one of the 2 rooms stopped working completely. I've tried tweaking nearly every parameter in Fibaro, copied the exact same parameters of the other dimmer 2 and searched and read all related topic, still couldn't figure it our.
Normally when calibrating, the LED light brightens up slowly and dims down slowly, but now it just flashes once then straight "Overcurrent detected. Check the connection or reduce the load connected to the output."
The dimmer is connected to 2 x dimmable power supply, and each power supply drives about 6m of 9w/m 24v white LED strip. The other room has similar setup with no issue.
Attached is the spec of power supply.
Any help would be appreciated.
Edited by fdsjkl3 answers to this question
