In a QA I use fibaro.getValue(deviceID, property) to get the property value. I also need to set a device property value
but I can not find a corresponding fibaro.setValue function. How do I set a device property value from within a QA?
    OK. In a normal programing environment you would expect an error message if you tried something that is not possible. ?
    Thanks for the help anyway.
    Yes, that's a very reasonable expectation . Unfortunately Fibaro made it easy for themselves but difficult for developers. (long rant
    So, fibaro.call returns nada, that we know.
    A fibaro.call is translated to an api call that look like
    the updateProperty call could look like
    Most api calls (I haven't checked all) returns an error (HTTP 404) if the device doesn't exist. However, fibaro.call doesn't return that to us, it just silently ignores it without telling us.
    If we call an action in a QA that doesn't exist we don't get any message back either from the api.post - just a HTTP 202. We can go to the called QA and have a look and see that it will complain in the log that there is no handler for that action. But the caller gets nada.
    If we with this api try to update a non.existent (or read only) property we get also an HTTP 202 back
    ...However, 202 is kind of "non-committal"...
    It sums up pretty good Fibaro's relationship with it's users - non-committal ;-)
    ...so I guess by reading the fine-print we see that they get away with this behaviour...
    ...but they could at least throw us an error if we try to access non existent devices?
    (The "REST" people advocate 202 if you need asynchronous requests, but recommends 200 if the result can be calculated reasonable fast. If you return 202 they also recommend that you return a ptr to a resource that can be queried for the result...
    From RFC7231
    If there is to be a market for QAs we can't put all the burden on the users of the QA. Calling the QA wrongly is just met by silence and in best case they have to go into the log of the QA to see if there were any errors - or into the swagger interface to see if it was updated?
    To be clear, I do not advocate all api requests to be 200, but more of them could check the validity of the request as it is often easy to check and return something better than just 202... and even if the api is asynchronous the Lua fibaro functions could hide that as show in this
    but it is unnecessary cumbersome if we don't have better error messages from the api...
