Hum, easy problem I think : Argument does not pass [SOLVED]
Why ? Each calls the same function and the same argument
thx for your help
Edited by jwetzel
update
4 answers to this question
thx for your help
So Auth:login(fun) calls the fun eventually?
In the first case the variable 'boolean' is not passed to the function in self[self.model][object]
and in the second case it's passed to RTV1905VW:setWifi(boolean).
Is it so that the function in self[self.model][object] is a class method? Then you need to pass 'self' as first argument.
    Yes, Auth:login(fun) call fun.
    In the first case, I call in my class with
    it's for self[self.model][object], self.model is text variable for "RTV1905VW", object is the text variable for "setWifi".
    Call is : self.RTV1905VW:setWifi
    The difference between calls functions is first call with self.RTV1905VW = RTV1905VW:new(app)
    and other call is direct call function with RTV1905VW:setWifi().
    I don't know if I was understandable ^^
    Yes, I save boolean result in self and get in another class with self.class.boolean. That not sexy, but it work.
    thx
    thx
    Well, my thinking was that if it was a class method this would work
    - self[self.model] is an object.
    - self[self.model][object] is a method of that object
    Because it's a class method you need to send self (the object instance of RTV1905VW)  as the first parameter and the self is self[self.model]
    More verbose:
