    have a look in recovery mode what the firmware on the other system is (system a/ system b)
    28 minutes ago, akatar said:
    посмотрите в режиме восстановления, какая прошивка на другой системе (система a / система b)
    On which one, master or slave controller?
    Both,
    You have a change to fix this if there is a 5.070
    4 minutes ago, akatar said:
    Оба,
    У вас есть изменение, чтобы исправить это, если есть 5.070
    We are waiting for remote access to the node ??‍♂️.
    i am also waiting.....for days now.........
    I'm waiting for remote access too.
    We are working on it and have a lead (we know what happened but searching for a cause).
    Please restore 5.070 version for now if someone have issues with GC if possible.
    If someone want to stay on 5.080 please pm me and we will try to fix this remotely.
    @m.roszakPlease fix by remote access.  I already PM you with access information.
    We are going to version 5.070.42. We hope that the reverse transition is possible.
    It worked for me, so can't think of a reason why not
    So far, the renovation is hanging at 33% percent, and for quite some time now. Should you start to get nervous?
    This part wil take a while, just hang in there
    did you choose repair of change to system a/b?
    We chose Restore with version
    Try disconnecting the slave gateway and reboot the master. After that, reboot the slave.....
    i don't think that will work. in my case, id didn't.
    Thank you @m.roszak and Fibaro support team.  They remote access and fix the new firmware problem.  Now I stay with this new firmware with no problem now.  But for others who use Master and Slave setup, please hold off this upgrade.  This problem will be fixed in the next update.  The team already find the source of the problem.
