Various device settings under "General" and "Advanced" tab are not saved on Slave Gateways!
Here the list:
General tab
  • Category
Advanced tab
  • Polling time interval
  • Invert logic
  • Energy Consumption - Take into consideration indications in the Energy Panel
  • Meter Configuration - This setting affects a way in which historic data is calculated
As soon as I adjust a value, it is reset to the standard value some seconds later.
I tried Soft reconfiguration, Complete reconfiguration, Remove and Add the device but all without success.
Same devices work perfectly on the Master Gateway!
Maik
Thanks for the report, we will check it out :)
happen to me the same.  hope they will be fixed in the next update.
