There is the following note in the changelog on Version 5.080.12...
CAUTION - updating to version 5.080 is not recommended if gateway connection feature is in use. Due to an issue resulting in Z-Wave engine switching, devices added to slave gateways may become unavailable. The issue will be resolved in the next update.
Does this warning apply only to Z-Wave 3.0 or to the update in general?
My HC3L is running as slave gateway in version 5.080.9 with Z-Wave 2.0 and i want to keep this Z-Wave version! Just want to make sure that this update will not destroy my configuration.
Thx in advance.
Maik
the only change in 5.080.12 is the new PKO Plugin:
Nothing else changed, so simply don't install that update (even if your already on 5.080 with master/slave setup)
Edited by tinman
would be nice if there fix the master/slave bug
Working on it :)
would be nice if there fix the 2n Gold intercom bug
