Feature request cloudcover scenes
Hi everyone,
I am not sure if this is the correct place for my request. Or maybe my question is already resolved by someone before me. Apologies if that is the case, I did try to search first.
In general I am very happy with HC3. It is easy to create scenes. One issue I do have is the option to distinguish between cloudcovers. I would like to have the option to choose running a scene on the amount of clouds. For example in meteorological forecasts and reports there is the mention of Few, Broken or/and Overcast; indicating the amount of clouds.
This would be helpful to me when running the scenes for the screens in front of the windows.
Thanks in advance!
13 answers to this question
You could use the QuickApp for OpenWeather, it has a child device with Cloud percentage.
with LUA scene, you might check the property (when using YrWeather) conditioncode, and make scenes based on it
This also looks interresting
Can output a Json, with a shitload of data from your location.
Like this conditionCodes = {unavailable = 3200, clear = 32, rain = 40, snow = 43, storm = 38, cloudy = 30, fog = 20,} ?
You could build it @ppeterr, you next challenge ?
Edited by SmartHomeEddy
@SmartHomeEddy
First little project will have something to do with Somfy....and then complete all the the other stuff...
For now i'll skip this challenge :)
OWM is not always give the correct % of clouds sometimes they miss it complete so you need to create alternative for in case.
I use % Clouds and correction for months to open/close curtains.
Succes,
//Sjakie
i see you are using already proper values, in the default weather QA they still wrong.
Btw, these are not the only codes, there are more icons available, /assets/icon/weather/normal-set/1.svg
The full set of icons is:
1->18, 19d, 19n, 20,21,22d,22n,23->36, 37d,37n,38d,38n,39d,39n,40->44,45d,45n,46d,46n,47d,47n,3200
Last time yrWeather  was broken, Fibaro simply fixed it asap to give us something working, but not implemented all codes into to it (yet).
However, we can do it anyway if we need more nice icons displayed
I got them from you ?
What do the mean?
Did I found them?
exact
    Thanks everyone for the information, I really appreciate this. I'll give this a try, probably fail horribly and will come back to this topic ?.
    it isn’t a fail, it is just a way that doesn’t work ?
    Easiest way turned out to be to download the plugin of
    . Enable in the plugin (devices/Openweather Provider/ Edit & Preview) the device "cloud cover" and add this "device" to a block scene. Then you can activate a scene with a percentage of cloud cover.
    Edited by U-B74
