HOW TO CONTROL FIBARO ON WEAR OS
Nyko
Dear users,
Can someone please tell me how i can setup my galaxy watch 4 (wear OS) to work along with the YUBII app. i cant get this working in any way
Much tanks in advance for an awnser!
Grtz Wesley
12 answers to this question
same problem here.
yubii or old app.
Thx
Edit: it seems that the problem is WearOS3
Edited by Bloug
I also have problems with wear Os and Fibaro.
I have Wear OS 2.32 installed on a smartwatch, on which I cannot install the fibaro wear OS APP.
From the latter you should be able to use the scenes installed on your HC3/HC2/HCL.
Running Google Play from the smartwatch, no Fibaro or Yubii smart watch app can be found.
The only "smart watch" option is found on the smartphone Yubii app, under settings-settings of the application-watch, and I put it to on.
But nothing.
Is there a way to run scenes from the smartwatch ?
Same problem here. I bought a Samsung Galaxy watch 4 so I could use this feature. Could Fibaro fix the problem that should work.
To date, the yubii app has reappeared under wear OS in my smartwatch.
Wear OS 2.26
Google Play services 21.18.16
The scenes work.
Maybe because I did a reset of the clock?
Any root cause why the app doesnt appear? Phone (S21) and Watch (4) all up to date. Watch features in Yubii app enabled but not possible to find watch app or scenes. Would be nice to not waste time on watch reset.
In my case, the app works.
Yubii Version 1.17.0
After the reset, the watch os automatically updated to :
Wear Os 2.38
Google Play Services 22.36.16
and continue to work ...
Watch: Ticwatch 3 Pro
/monthly_2022_10/image.png.97a98d5597d22c546acb47be443b1652.png" />image.png.7ee70f932a3d5e20a2f143874fd8fcb4.png
Edited by clafib
images posted horizontally instead of vertically
I there any update? I'm not able to find any app for my galaxy watch 4.
At the moment I'm getting more and more disappointment to spend over 3K for Fibaro Devices and they do nothing over years for bugs of bugs!
