Showing results for tags 'home center'.
Dear users, Can someone please tell me how i can setup my galaxy watch 4 (wear OS) to work along with the YUBII app. i cant get this working in any way Much tanks in advance for an awnser! Grtz Wesley
- 13 replies
[How-to] Add your Ring Doorbell to the Fibaro HomeCenter
Joep posted a topic in Tutorials and Guides
Is it allowed to post an integration to Home Center with third party support tools? I hope so, because this is awesome! My goal: Show the latest ringer at my front door in the Fibaro Home Center App when using my Ring Doorbell. The Challenge: Ring.com has no official API and snapshots are not possible at the moment. Fibaro does not support Ring Doorbell and Home Center and LUA code is not able to download a video and extract a frame from it. How I fixed it? I run a Node-RED box on (Debian) Linux. I installed Python with the Python Ring Door Bell Library to download the latest ringer video and ffmpeg to create a snapshot image. I use Node-RED to serve this snapshot with HTTP to the Home Center. You can also use NGINX, Apache or whatever webserver you like! This post is for experienced users, I skip a lot Linux stuff. A more detailed approach is on my website (see my signature). 1. Install Python, pip and ffmpeg (of not already present) on your Linux (Raspberry/NUC/etc..) box: sudo apt-get install python python-pip ffmpeg 2. Install the Python Ring Door Bell Library: pip install ring_doorbell 3. Create a folder and download my FibaroRingCam.py script to it: mkdir FibaroRingCam cd FibaroRingCam wget https://github.com/joepv/fibaro/blob/master/FibaroRingCam.py 4. In the script you have to edit the following lines with your own (login) information: myring = Ring('[email protected]', 'password') mypath = '/home/joep/FibaroRingCam/' 5. Now run the file. You can run it as a service, but that is out of the scope of this topic. 6. Serve the snapshot with Node-RED to the Home Center. Add the following node to Node-RED and edit the path of the file node to the path of the last_ding.jpg snapshot. If you want to use another webserver configure it to serve the snapshot: [{"id":"d1f4395b.cd0778","type":"comment","z":"30de6047.723c","name":"Fibaro Ring Camera Snapshot","info":"","x":160,"y":180,"wires":[]},{"id":"e42e6aeb.e610e8","type":"http in","z":"30de6047.723c","name":"[get] /last_ding.jpg","url":"/last_ding.jpg","method":"get","upload":false,"swaggerDoc":"","x":130,"y":220,"wires":[["9329fca.9bf87"]]},{"id":"9329fca.9bf87","type":"file in","z":"30de6047.723c","name":"last_ding.jpg","filename":"/home/joep/FibaroRingCam/last_ding.jpg","format":"","chunk":false,"sendError":false,"x":350,"y":220,"wires":[["5dd8cb15.ea08b4"]]},{"id":"5dd8cb15.ea08b4","type":"http response","z":"30de6047.723c","name":"serve last_ding.jpg","statusCode":"","headers":{"content-type":"image/jpeg"},"x":590,"y":220,"wires":[]}] 7. Add a new camera in Fibaro Home Center 2: 8. Give the camera a useful name and change the advanced settings to the following settings: IP address: node-red ip address:port JPG path: last_ding.jpg MJPG stream: last_ding.jpg Note! The MJPG stream does not work, you have NO video! I’m still searching for a solution to play the last Ring video as camera stream. The result in Home Center 2: And in the Home Center App: What the Python script does? It logs in at the Ring.com servers and checks every 15 seconds if there is a new ring. It saves a local file to know if the last ring is a new one. If the ring is new, it downloads the lastest video and feeds it to ffmpeg to extract 1 frame to create a snapshot.- 9 replies
- 4
- http server
- ring
(and 5 more)
Hi, I'm new to Fibaro (HC3) and just finding my way around things. I've seen some reference in other forums that Quick Apps (buttons / controls) are not currently available in the Home Center mobile app - is this correct and still the case? Seems like a pretty basic requirement to be able to use Quick Apps doesn't it, or am I missing something? Otherwise, what is the point of them and how do you use them from your mobile other than building individual scenes for each action you want to take with it? Is anyone aware of a mobile app update on the horizon soon which will allow control of Quick Apps from the mobile app UI? Thanks
Witam Czy komuś działa scene wyzwalana przez lokalizacje gps urzadzenia z zainstalowana aplikacja Home Center?
- 2 replies
- gps
- home center
Would be nice to be able to activate/deactivate all the sensor in one button. Now I have to activate/deactivate all my motion sensors one at a time. It's really irritating having to enter my pin on every sensor Beside that, its a nice looking app!
- home center
- alarm
Wall plug - wifi instead of z-wave
The Emil posted a question in Other Devices / Third-party devices
Hello, Today I have a HC2 with a lots of z-wave devices (Fibaro walls plug, motion sensors...). That works perfectly in the main building. Now I need a wall plug in another building 100 meters away. To far for z-wave. That building is on the same wifi as the main building and all wifi gadgets (camera...) work there. Does anyone know how to get a HC2 controllable wall plug in that building? As I see it, my "options" are: 1. Find a HC2 compatible wifi wall plug 2. Find a wifi wall plug with an open api and do a little LUA programming in HC2 3. Find a way to extend the z-wave network over tcp/ip. This must be a common problem for all with several small buildings (garages etc.)- 20 replies
Hello! Yesterday a new article was published in our Knowledge Base: FIBARO Intercom in FIBARO Home Center Interface The article presents how to connect the FIBARO Intercom with our Home Center and general interface appearance. I think it's quite informative article and it's worth reading it : )
- 2 replies
- interface
- home center
I am reading through the intercom manual and still there are some things not clear to me: The intercom does not support the Zwave, how does it communicate with the Home center? Is it possible to control a gate via an actor and not with the internal intercom relays? if not what's the benefit to have it installed together with a Fibaro installation?
Hello guys, With new feature, that thermostat will be excluded from Heating panel, is it somehow possible see when Thermostat will be included to heating panel again? Also, is it possible force it to include into Heating panel again? Best regards, Jakub
Hi I have thought of making my home automated an are considering Fibaro sense a friend of mine are using it. i have a few questions before i buy stuff and might not need the things i buy. i though to learn to program in C# with this system to envole my programing skills. Questions: Home center. is that a server to make things easier but not so free as to make your own server. is it hard to make things work without homecenter? security is it better to install everything as a standalone system or is it best to use it on web my consern is security? does the system comunicate with telerams or as a PLC I/O? so if i would start do i need homecenter or can i use my own computer and wireless network to make it work or is it hard?
- 1 reply
- home center
- home
- (and 4 more)
Hello there, Till i write ticket to support i want to ask a community. First of all customer has HCL, so please no lua. Jest received info from a customer that notifications does not work on his iPhone 7. Do you experience same issue or is it working for you? Customer has set some push messages in Notification panel. He set some push on device status change (device configuration) and made some scenes for it. Those scenes were starting manually. Maybe there is topic regarding that and if is, please point me to it. But i do not want to "necrofile" old dead topic.
Witam, czy ktoś może mi powiedzieć jak wprowadzić centralkę Home Center w tryb recovery? Jedyna dostępna instrukcja obsługi, woła o pomstę do nieba - powinna być raczej ulotką reklamową.. http://www.fibaro.com/manuals/pl/HCLite/HCL-PL-web.pdf Proszę o wskazówki, bo mam taki komunikat: Backup file error Please Wait Backup file is corrupted. Please try again.
- 3 replies
- hcl
- home center
DVR Integration - HDCVI/Analog cameras
akshayhuria posted a question in Other Devices / Third-party devices
Hi everyone, Is there a way to integrate a dvr based camera with our system? It looks like we just need a jpeg and mjpeg path to add a camera, but cant seem to find a path for different channels in a hikvision DVR. Any help would be useful. TIA! -
Hi, Currently i am using HCL as the controller for the z wave devices. I intend to buy a Home Center 2 (Hc2). Is it possible to make HC2 as the main controller and HCL (home center lite) as the secondary controller? Will I able to control the devices connected to HCL using HC2?
