NICE BiDi remote control
Guest Rafal_ll
Guest Rafal_ll
Problem with using the NICE BiDi remote control with Fibaro
We have the ON3EBD remote, we only program one button on the gate in the OXIBD module.
There is a great gate works, we still have two free buttons.
I want to add to the HC3 control unit, I go through the entire procedure until the room and name are assigned, there should also be pressed the buttons that we want to use, and it does not work, it does not recognize any button.
Only a pure remote control that has not been programmed anywhere can be added to Fibaro. If we add one button from such a remote to the control unit, all buttons are occupied anyway and they can not be added anywhere, e.g. to OXIBD
The remote control can store 10 identity codes of radio receivers, so you can program each button separately with another receiver, but not with HC3
Is there a solution to this problem
Nice mode two is missing in HC3 integration.
Edited by Rafal_ll
