How to control the led of Walli Switch from zwave controller
Hello everyone,
I would like to buy the walli Double Switch (FGWDSEU-221) to control one light but also as notification system using the led ring. Is it possible to control the led (on/off, color, brightness, etc...) directly from the Zwave controller using specificing commands? I looked at the manual but I waasn't able to find any useful information and I understood that it is possible with Walli Controller (but I want to control also a load therefore I want to use the Walli Switch).
Thank you
Giaco
7 answers to this question
    22 hours ago, SmartLifeSystems said:
    Yes, you can.
    Thank you SmartLifeSystem. Can you explain how I can do it? Following same commands described in the manual of walli controller? do you have any examples?
    Edited by Giaco
    You should be able to change it with a scene
    do you have an example of a possible configuration/command? I am using Fibaro devices with RaspberryPi and ZBerry and HomeAssistant.
    Thank you in advance
    Giaco
    @Giaco
    I use a simple scene to control the LED. But since its LUA not sure if thats of any help because your not using a Fibaro Home Center.
    Edited by Remi
    8 hours ago, Remi said:
    @Giaco
    Thank you. I will try to play a bit but I think I need the Zwave Property ID for the functions "setRingOnColor" and "setRingOffColor".
    In the manual they are not mentioned and I am not sure where to find them.
    Edited by Giaco
