andyb749 4
So, I've just recently got the HC3 and so far its been a bit of a battle to get it working any where close to the HC2.
Out of the box, the setup script didn't work and it took a couple of iterations before I got through it.
In no particular order here's some of the issues I've encountered to date:
* The GUI is very slow, sometimes to the point that mouse clicks are missed, and certain portions of the GUI are not rendered.
* The time can be out. At one point the clock on the banner was showing 1551, but the history was showing events with the correct time of 1630.
* A lot of devices will appear as unavailable - in particular all my Fibaro Motion Sensors and Popp TRVs. I've changed some parameters on the Aeon/Aotech device I have as I suspect the network is busy
* The Fibaro motion detectors are not detecting motion, they are reporting temperature, lux and will flash on the device when motion is detected... but not in the web UI.
* Fibaro door/window detectors are not detecting doors opening. They appear to be reporting temperatures OK
* Secure SRT Thermostat. One of these works, the other is reporting a temperature at least 10C higher than the room
* Secure SRT Thermostats & Popp TRVs. There is no ability to set a temperature setpoint on these, and in the climate panel there's a warning that they may not work. They do work using the climate panel
* Fibaro RGBW. The on/off button does not function and it doesn''t look like RGBW mode is supported. In fact, when included the RGB panel was hidden and five individual sliders were shown instead. It is impossible to control from any scenes. Setting a colour slider causes multiple entries to be logged in the history - one from user with set colour, then two, three, sometimes more from system with completed incorrect RGB values.
* Everspring ST815 Light Sensor. Includes OK, never updates any value and doesn't send a command to the associated devices
* Lots of devices without templates
That's all for now, but these were all features that just worked in the HC2. In general, its not a good experience and trying to explain to my wife why she can't control the heating and that the lights in the kitchen aren't working is not easy.
Other things that I wanted was the promised support of Zigbee and RF433 protocols, but they appear to be a distant dream for now.
31 answers to this question
