REMOTEC ZXT-600 AC MASTER
Hello, I can't correctly add the remotec zxt 600 to home center 3 lite, it is recognized as 2 temperature sensors instead of a thermostat.
When I set parameter 27 (unsigned integer 2 bytes, right?) to the value of my Hisense air conditioner - 828, nothing happen, software reconfiguration of the device also not help and also remove the parameters value.
How to make it work? Is there any device template?
it is bug in current HC3/HC3 Lite system.
More info -
There will be version with the fix available soon.
