Guest jodohl
Hi!
The HeatIt Z-Smoke is a combined Smoke/Motion/Temperature detecor. I have just realised that the support for Z-Smoke in HC2 is faulty. Here is what happens:
The Z-Smoke motion detector will NOT trigger the Motion Detector device in HC2, but will trigger the Smoke detector device (!): The motion detector device will stay "Unbreached".
I have made contact with HeatIt customer support, who has confirmed that this is a known bug and states clearly that this is a Fibaro problem. My previous experience with Fibaro indicates that getting this fixed will be a walk in the desert.
Customer support also states that the problem is fixed in HC3. But I am NOT buying a new hub to fix this stupid error.
Therefore: Has anyone a LUA workaround for HC2 for this potentially very useful detector?
1 answer to this question
