Dimmer 2 associations not working on HC3
Rutgersson
I bought 50+ Dimmer 2 modules and a HC3 to my home and I have one Dimmer 2 module behind every double momentary switch (connected to S1 and S2 respectively, but no load connected as these are supposed to only be behind the switches). Now I need to associate it with Dimmer 2 modules connected to every lightning point that we have (one Dimmer 2 connected to each lightning and these work to be controlled from the HC3) but I cant make the associations work from the modules behind the switches. How do we make this happen?
I have tried every guide and tips on the forum without success.
Thanks in advance.
Best,
Christoffer
Thanks in advance.
Best,
Christoffer
The dimmer needs a load to function correctly. Fibaro bypass would also work.
