wujo 5
Hi everybody
since some time, I tried to find a solution to get announcements about the status of some devices (like "the window is still open") from the HC2/3. All the solutions I tried were not satisfactory to me, so I gave up. The solutions I tried were:
1. TTS using Raspery as PHP server as published by iqhouse. This solutions worked well but needed a periodic update of a cooky from Amazon. That is not acceptable for a productive application.
2. TTS using Raspery as PHP server and a bluetooth connection to Alexa. Prerecorded audio files were the output of a media player at the Raspery. This finally was also working but with great difficulty to get the bluetooth connection activated. The bluetooth link was very unstable and needed often reconnections with great effort. That was also not practicable for me.
3. same as 2. but with active loudspeaker connected to Raspery. That worked well and stable but needed an extra device. That was the reason, why I didn't love it either.
Now I found an alternate solution, very simple to implement and which is stable working since some weeks with my HC2 and HC3. As I found nothing like this in the forum, I would like to share it with you.
It is based upon a skill for the Amazon Alexa namen "voice monkey". You need an Amazon account to log in at the home page of voicemonkey. There you download the skill to Alexa and generate a so named "monkey" with the text you want Alexa to tell. As a result, you get a HTML link you can integrate easily in a QA(HC3) or scene (HC2). The HTML command includes the address and the text. So easily, dynamic output can be generated as well, like the actual temperature.
I think no further explanations are necessary, as all steps are self-explaining at the homepage or already described at that forum.
good luck.
7 answers to this question
