dmtcs 0
Hello everyone,
I have just integrated several Simon iO actuators with HC3 and there is an issue with the devices' state which does not change properly neither in the web interface nor Yubii app. This happens for the following actuators:
- Simon 100 iO Roller Shutters
- Simon 100 iO Dimmers
The update of device's state is not automatically reported to web interface/app when pressing manually the roller shutter switch or dimmer.
The same happens when the device's control is coming from the app/web interface. For example, you set the shutter to be closed (0%) but the state in the app/web interface still shows opened (100%).
I am using Z-Wave 3.0 and the HC3 firmware version is 5.080.20.
I tried to force this communication between the devices and the HC3 through associations but with the same result. Apart from this, there are no templates for the Simon 100 iO devices and I can not add/modify any parameter in the web interface (don't have the option in parameters) or poll them. For example, I can not set a basic_report command to the controller when the devices change their states in order to force their updates in the system.
Is this due to Z-Wave 3.0 and a HC3 firmware update which has not come yet?
Has anybody any suggestions?
Thank you in advance.
Regards
