Add Device in Security S2 mode
Hi guys,
I recently bought a Fibaro HC3 with some devices. One kind of these are the heat controller.
I can't figure how to add these devices in Security S2 mode, I tried both the manual and aearching on the forum but I did't figure out how to do it. I just succeded just to add in S0 mode.
Best regards
Raffaele
S2 is only available when you switch your HC3 to zwave engine 3, which i currently in beta stage.
/monthly_2021_11/image.png.77d9da467a76103c7d66107a37f83082.png" />
To do so, you need to reboot to recovery and do factory reset. After first boot you will be asked to select zwave engine. You will have to create all scenes from scratch, and re-include all devices. All backups made with zwave engine 2 are not compatible with zwave engine 3. This is the current situation, and as there are not all devices supported/clear implemented, Fibaro does not recommend to use it in production environment.
However, there will be one day migration path/wizard, which will allow users to switch zwave engine without losing anything, however only Fibaro can tell you how long they need to release it.
    Hi Tinman,
    thanks a lot for your quick answer...
    Since I'm new on this system i'll continue for a bit with the zwave engine 2....
    Best Regards
    Raffaele
    Has there been any progress on making Security S2 mode a standard option or it's still in Beta?
